Author Topic: 2 button remote 1999 omega with factory alarm help  (Read 2033 times)
Shark1e
  • Stoke on Trent
    • Meega 2.5TD-CD Estate
« on: 12 September 2011, 21:03:36 »
Hi all,
searched for this but not found anything,
went to open the tractor with mrs spare key, not lighting up on the remote, opened popped in new battery still dead, i have in the past resoldered 2 new micro switches and repaired the snapped battery leg back on.
so looks like a new remote. but which one???? where do i find the part number? mine has m-am 433.92 mhz
trying to get one off fleabay so i can swap my blade to the new remote and "My Naff Code Reader" it back in synch etc.
any ideas folks,
thanks rob
2.5 cdtd omega 1999 manual estate Chipped and poorly at the moment -  is there a doctor in the house
Re: 2 button remote 1999 omega with factory alarm help
« Reply #1 on: 12 September 2011, 21:25:14 »
Need to get one that matches the same type - betting yours is Megamos from spec/age.
Be aware using "My Naff Code Reader" to program the Alarm ECU, I've seen destroyed Alarm ECUs with that.
Shark1e
  • Stoke on Trent
« Reply #2 on: 12 September 2011, 21:38:01 »
Yes mate megamos but as none one fleabay say megamos. how can i get the same type?
« Reply #3 on: 12 September 2011, 21:45:15 »
Find someone selling the megamos one ;)
« Reply #4 on: 12 September 2011, 22:07:08 »
toysr1
  • Newark
« Reply #5 on: 13 September 2011, 12:22:55 »
Hi
Regarding the non working fob, have you checked the battery holder to circuit board connection, I've had this break on two fobs and it's not always easy to see the break, in both cases a repair was made using an axial lead of a resistor or diode, works fine still.
hope this helps
toysr1
Shark1e
  • Stoke on Trent
« Reply #6 on: 13 September 2011, 19:08:18 »
hi done this fix once on the battery to board etc but will check again, did mange to get a megamos m-am 433.92 last might for £10 all in off flea bay so have to wait for it to arrive.
will keep you all posted.
thanks rob
Shark1e
  • Stoke on Trent
« Reply #7 on: 16 September 2011, 20:11:08 »
got another fob from fleabay supposed to be a megamos m-am 433.92 so he says,
i can't find any writing on it except 08554201 & 01425677
via "My Naff Code Reader" i can erase all keys and transponders no probs,
i can reinstall the keys and transponders
i can erase all remotes no problems, but "My Naff Code Reader" not picking up new remote when in learning mode, treid everything, my original remote can be erased and then once in learning mode in "My Naff Code Reader" it say remote activated successfully or a like the minute i press the lock button on the original.
is this the wrong remote fob or am i doing something wrong
« Reply #8 on: 16 September 2011, 20:21:36 »
via "My Naff Code Reader" i can  ....
It'll all end in tears ............  ::) ::) ::)
Shark1e
  • Stoke on Trent
« Reply #9 on: 16 September 2011, 21:08:00 »
tears of joy my good man tears of joy. :y
Hi Ho Hi Ho it's off down my workshop i go lol
took the soldering iron back to my spare key and found it was the battery fix i did, somehow worked loose,
now "My Naff Code Reader" in hand back to the meega to reprogram as i had already deleted all remotes, success my good man, both keys working and reprogrammed.
looks like the fleabay one is in the next post back.
if i get another off there i will try it and report back, thanks to all
rob
Shark1e
  • Stoke on Trent
« Reply #10 on: 30 September 2011, 14:49:21 »
all sorted got a 2 button m-am megamos from fleabay for under £10 and zip zap with "My Naff Code Reader" and all working hunky dory, no tears this time. :y :y :y
« Reply #11 on: 30 September 2011, 16:24:37 »
Excellent news :y
Martin_1962
« Reply #12 on: 01 October 2011, 21:16:28 »
I used tinned brass wire - haven't had one escape yet.
Page created in 0.039 seconds with 20 queries.
