Author Topic: cruise controll  (Read 1409 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
cruise controll
« on: 20 September 2009, 06:24:11 »
had a faulty stalk when i bought the car main beam kept flashing cruise didnt,bought a new talk with cruise controll same as i had.but cruise controll doesnt wotk!is there a fuse that might have blown?all is connected up correctl,both sets of wires.pretty good with wiring etc so any help would be appreciated!
scream if you want to go faster!!!
    • Zafira Tourer & BMW 435i
Re: cruise controll
« Reply #1 on: 20 September 2009, 10:29:08 »
how many wires on the leccy connector for cruise on the replacement stalk?
mr ICE man
  • dolgellau wales
Re: cruise controll
« Reply #2 on: 20 September 2009, 20:05:18 »
has 2 wires seperate from other connecter
Re: cruise controll
« Reply #3 on: 20 September 2009, 21:26:08 »
You haven't fitted a 4 wire stalk to your car - 2.5td engine needs 2 wire stalk.
mr ICE man
  • dolgellau wales
Re: cruise controll
« Reply #4 on: 22 September 2009, 20:49:35 »
is def a 2 wire stalk and connecter but not working
Re: cruise controll
« Reply #5 on: 22 September 2009, 21:18:19 »
check functionality by sticking meter across wires - the switches are in a resistor network.
I dont had td stalk to give you correct readings
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: cruise controll
« Reply #6 on: 24 September 2009, 11:35:50 »
Across the pins (disconnected).
Normal (No Cruise), 670 Ohm
Cruise On / Speed Increase, 67 Ohm
Resume / Speed Decrease, 162 Ohm
Reset / Stop, 1.6K Ohm
Chris.  :y
Page created in 0.046 seconds with 20 queries.
