Author Topic: Facelift door  (Read 1183 times)
...Matski...
Facelift door
« on: 16 February 2011, 09:11:12 »
Hi all,
I had a dented passenger door on a 99 omega. I was wondering if a 2000 (facelift) door will fit as I think I've found one in the same color (z144 met gray)
Thanks in advance,
Matt.
Re: Facelift door
« Reply #1 on: 16 February 2011, 09:18:59 »
Yep, it`ll fit.
...Matski...
Re: Facelift door
« Reply #2 on: 16 February 2011, 09:23:56 »
Great thanks.
I take it it's just the mirror and card that are different? Presumably I could get the other mirror too?
« Last Edit: 16 February 2011, 09:27:39 by ...Matski... »
Re: Facelift door
« Reply #3 on: 16 February 2011, 09:26:13 »
You`ll have to swap your door loom over (easy enough) unless the donor door is from an Elite.
« Last Edit: 16 February 2011, 09:27:11 by RobG »
...Matski...
Re: Facelift door
« Reply #4 on: 16 February 2011, 09:28:45 »
Thats grand I'll swap the guts out. Will the older loom work with the new style mirrors?
Lastly are the chrome trims possible to swap?
« Last Edit: 16 February 2011, 09:29:43 by ...Matski... »
Re: Facelift door
« Reply #5 on: 16 February 2011, 09:39:13 »
If you mean the bump strip.....the facelift is held on by a small torx either end & slides off, yours will be bonded on, will come off with time, patience & heat. Don`t forget to use your speaker as your`s being an Elite will probably have Bose. Mirror will work
« Last Edit: 16 February 2011, 09:39:34 by RobG »
Re: Facelift door
« Reply #6 on: 16 February 2011, 09:41:51 »
...Matski...
Re: Facelift door
« Reply #7 on: 16 February 2011, 09:46:01 »
Nice one thanks for your help.
Getting the trim off to refit looks tricky!
Re: Facelift door
« Reply #8 on: 16 February 2011, 09:47:40 »
May be worth contacting VX getting cost for replacement :-/
...Matski...
Re: Facelift door
« Reply #9 on: 16 February 2011, 09:53:13 »
I'll have a go first then spend out when I stuff it up!
Page created in 0.033 seconds with 20 queries.
