Author Topic: LPG Sparking plugs  (Read 1017 times)
MartinP
  • Dudley
    • BMW 320D
LPG Sparking plugs
« on: 25 September 2010, 21:01:08 »
Which plugs should I be using?
Currently do approximately 250 mile/week
95% on LPG.
Changed the plugs for a less worn used det, so now I need to buy the right ones.
Martin
    • 530D M Sport, Elite 3.2
Re: LPG Sparking plugs
« Reply #1 on: 25 September 2010, 21:05:00 »
Think Marks DTM recomends the twin electrode GM ones for LPG.
« Reply #2 on: 26 September 2010, 14:34:21 »
Standard GM plugs are fine on LPG. No need for anything exotic. :y
« Reply #3 on: 26 September 2010, 16:58:21 »
Stock 4electrode here, no issues...except they worked loose on the 246 bank, ESP 4 that was giving a miss fire code, soot all round the base and the coil PAC rubber, undid it by hand with plug socket and extention.  :o
...not an LPG plug related issue, but Master dtm has since mentioned torquing to 25nm, which I'm fairly sure I did, but also going back over them all 6 once again with the torque wrench as the crush washer can sometimes relax...I know I did not do that when fitting the loose ones.
Other than that the plugs looked in very good nic after 30k. But replaced like for like again while in there.
Hth
« Reply #4 on: 26 September 2010, 17:47:30 »
Just the stock  Bosch twin electrode on mine & no issues at all :y
    • Zafira Tourer & BMW 435i
« Reply #5 on: 26 September 2010, 21:20:17 »
stock GM twins here, done about 30k miles (13k on LPG) - No issues  :y
MartinP
  • Dudley
    • BMW 320D
« Reply #6 on: 26 September 2010, 22:37:34 »
Thanks all, job when I get back from hols.
Martin
DodgeyDave
  • Northumberland & London
« Reply #7 on: 27 September 2010, 01:03:33 »
I've used the standard GM ones and done 70K in last 2 years, 99.9% on LPG, no issues at all :y
