I run a 2000 (X Reg) 2.5 Elite Auto 4 speed Facelift.
I am experiencing what I can only describe as 'hunting' (similar to a misfire under load) when the auto box changes from 3-4 and even when in 4. This seems to be when accelerating normally at speeds between 50 and 60mph. I noticed that in the post "Gearbox ECU Update Experiences" 'Lazydocker' had posted the following experience he had which I believe was related to an ECU (V9) upgrade: -
1999 3 Litre Elite...
Updated by Kevin Wood sometime early last year (or was it longer ago than that )
Anyway... Whole drive is a much more pleasant experience. Changes are far more positive and it doesn't hunt between 3/4 gear when cruising at 50ish as much.
Downside: When towing the van it will kick down more readily than before and hold 3rd (which is great) but is more reluctant to change back to 4th if on the slightest incline... Incidentally, if you turn the cruise off and use your foot on the pedal this is easy to overcome.
Is what I am experiencing related do you think - and how do I go about checking which version of ECU firmware I have and updating it?
Many thanks
Hi,
Just thought I'd post the conclusion to this problem. The symptom worsened since the first post so took it to my local GM repair agent (Troops of Leadenham). They diagnosed a faulty Coil Pack and #5 HT Lead. Unfortunately the Coil Pack (after market version) had only been fitted last October so was somewhat surprised.
![Shocked :o](http://images.omegaowners.com/forum/smf2000/Smileys/oofstd/shocked.gif)
To cut a long story short I got Troops to stick a genuine GM one on and they threw in a second hand #5 HT lead. They charged me £180 for the Coil Pack and circa £90 labour (+ VAT of course)
![Angry >:(](http://images.omegaowners.com/forum/smf2000/Smileys/oofstd/angry.gif)
On the upside the suppliers of the after market Coil Pack (JRBK.TRADING) gave me a full refund and were very helpful and apologetic.
![Thumbs Up! :y](http://images.omegaowners.com/forum/smf2000/Smileys/oofstd/thumbsup.gif)
However I do need to locate a good repair man in my area (I am based in Wellingore, Lincoln) armed with a Tech2 that might consider looking after my Omega for all but regular service work (cos' Troops stamp my service book).
I currently have problems with my door locks - i.e. my passenger side front door plunger doesn't go down or up (well sometimes it does) when using either the key or RC.
