Had the MOT on the old gal today and the following came up:
- ABS system warning lamp - ABS fault indicated.
(the garage reccommend chucking it through a Tech 2 in order to ascertain if it's the wheel speed sensors rather than ECU as the symtoms seem to point to that)
- Offside Headlamp aimbeam image kicked up to the Offside
This one got me as it would seem that my offside headlamp is actually a euro-spec lamp! So back on with the original non projectors we go.
However, what was strange was that the hydraulic lifter problem I thought I had was actually an exhaust manifold gasket blowing - but it still got through emissions!!
The garage I've taken it to does all the taxi's and government vehicles in the area.
Question - exhaust manifold gasket blowing on Driverside cylinder bank apparently, so in terms of anyone having done one before, are there any tricks I should know regarding getting the infamouse studs loose?
What is worrying though is that the two rear shocks both have a light misting of oil on them. Not enough to fail on, as they were not leaking as such, but they were only put on in november, and are genuine VX items.
