hi guys, i wonder if someone could help, I have a 2.2 omega CDX w reg. a couple of weeks ago it rained really heavily, next morning i noticed the carpet on the passenger side is soaked and took sometime to dry it up , checked my coolant tank, water level seemed unchanged. 10 days later the engine gauge was reaching a 100 which's never happened before and it touched the red lines at one occasion, checked the water levels again unchanged, no noticeable water leak, no oil in water. heating and air con are working with no problems. Drove on motorway for 2 hours with no bother, but once stationary or in traffic jam temp climbs up again.
i've been to three garages and everyone tells me a different diagnosis. one said its the radiator, second said its the heater matrix , last one (which sounded more sensible to me although am not an expert) said its probably the thermostat....I am totally lost and dunno what to do and who to believe......any advice is much appreciated ....thanks in advance
Right, the water is east as that is the scuttle drain!
As for the over heating, heres some food for thought which will give you an idea how crap at least two of the garages are!
1) The heater matrix is not part of the engine cooling setup so will have no affect on the temp at all!. In fact, the flow through it can be shut off by the heater bypass valve when max chill is selected on the climate.
2) The thermostat is designed to fail open, so if it was failed I would expect the car to take an age to heat up. If it failed shut then there would be no/limited flow through the radiator and it would over heat even at speed.
3) The radiator is a possible but, they should have checked the surface temperature with a laser temp probe to see if there is any sign of blockages. Such radiator issues tend to come on over time rather than suddenly
My next simple step would be to check the fuses in the under bonnet ECU box (triangle shaped thing on the inner wing), one of these is for the front fan setup!
As for reaching 100 degrees, in this weather and in slow moving traffic, its quite normal, did you hear the cooling fans kick in at all?
