Author Topic: So what have you done to your car today?  (Read 3197915 times)
0 Members and 9 Guests are viewing this topic.
« Reply #6330 on: 10 November 2013, 21:19:16 »
Changed the thermostat finally  ::)
Yet another excellent guide, thanks to Daz and TB :y have a couple, or three, of things to suggest for it though...
1. Should have a NWS, The videos contain actual Rick Ghastley :o had forgotten about Dazzles love of all things pink ;D
2. The Bastid bolt was a piece of piss. The Tuesday hose clip wasn't  >:(
3. No suggestion of how many bits the thermostat/transfer pipe can come out in...
Cleaned the breathers out whilst at it, as the bridge was just starting to show signs of sooting up, pipes still nice and clean, and throttle body degunged too 8)
Swapped the two electric water pumps around so the radiator should now behave as it should. Ran upto temp find, temp gauge now goes above 75° so I have heating. Reconnected the vac pipe from the front multiram, so all in all, the fuel economy should improve, and I won't freeze ;D
Heater matrix can wait, pipe joints seem dry, so looking like it will need a new one :-\
Another positive find was that the Oil Cooler plate and Coolant Bridge joints are all dry :y
chrisgixer
« Reply #6331 on: 10 November 2013, 21:55:58 »
Av it! ;D
« Reply #6332 on: 10 November 2013, 22:19:37 »
After 257k I wasn't really expecting it to fall out ;D
« Reply #6333 on: 11 November 2013, 08:59:03 »
And this is why I'm still putting mine off... ;D
All I did yesterday was fill it, stick it through the car wash and drive it from Bracknell to Solihull, to West Heath hospital, Birmingham, back to Solihull and then back to Bracknell. Made it back with just enough fuel to do a commute run today..
Still stinks of burning oil. So that hasn't magically fixed itself yet.. ;D
« Reply #6334 on: 11 November 2013, 11:30:54 »
Ever the optimist. ;D
« Reply #6335 on: 11 November 2013, 12:32:49 »
It takes a while to burn six litres of oil one drop at a time ::)
« Reply #6336 on: 11 November 2013, 18:40:34 »
Ah, so the smell of oil on mine isn't a leak, but a bit of spilt oil? Excellent :P
« Reply #6337 on: 11 November 2013, 19:31:08 »
 ;D mine still smills of wd40 from the breather clean ::)
Heater and temp gauge both working as expected, and no Coolant warning on the MID, so guessing it's not leaking :-X
  • Auckland
    • Mazda MPV
« Reply #6338 on: 11 November 2013, 22:00:21 »
Found that I have a P0420 code  :(
What puzzles me is that I don't have the spanner light as a consequence :-\ (and it does have a bulb fitted so there  :P)
« Reply #6339 on: 11 November 2013, 22:17:08 »
Historical  :-\
  • Auckland
    • Mazda MPV
« Reply #6340 on: 11 November 2013, 22:26:05 »
I'll clear it then & tell it not to come back ;)
« Reply #6341 on: 11 November 2013, 22:27:41 »
Can see that happening  :D ;D
  • Auckland
    • Mazda MPV
« Reply #6342 on: 11 November 2013, 22:36:51 »
So long as the light stays off for the MOT I won't worry too much. I think it might be triggered by running on different fuel when we went on holiday so imagine it shouldn't happen again before the next MOT :-\
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6343 on: 11 November 2013, 23:15:04 »
EML won't matter for Mot as long as emission limits are met :y
other rides
  mk3 Volvo v70 2.0 Diesel ,Citroen C2, Pug 306 cabriolet
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
« Reply #6344 on: 12 November 2013, 05:25:43 »
Manual gearbox swap yestrday. At gearing I kept on hearing some strong creacking noise when gearing. Now it seems to be good. :y
C20NE - X25XE
Page created in 0.037 seconds with 21 queries.
