Author Topic: Y26SE Cam Cover Seals in one or two Pieces  (Read 2452 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 27 March 2024, 17:19:26 »
Just opening the package of Victor Reinz 15-34268-02 to install cam cover seals. Is it really so that there are two separate seals for one cover. I remember when I removed the old one four weeks ago that it was in one piece, there was some kind of 'Bridge' that joint these two seals together in both ends, so are these OK??
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Y26SE Cam Cover Seals in one or two Pieces
« Reply #1 on: 27 March 2024, 17:29:06 »
Older ones where linked IIRC
I fitted these to my 2.6 no issues  ;)
clicky link
polilara
  • Finland
« Reply #2 on: 27 March 2024, 17:32:20 »
OK, thanks, I used ELRING last time and they were linked acc to Autodoc picture, but if these are ok, I continue, thanks again.
« Reply #3 on: 27 March 2024, 18:22:14 »
From memory, I think it was the Elring ones that used to go hard very quickly, and leak prematurely...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 27 March 2024, 21:26:18 »
 With the supply of certain parts becoming nls, beggars can't be chossers,, and if GM still have them,, gawd knows how much they will be.
.Rinz was oe supply
Hoof'land storeman.
polilara
  • Finland
« Reply #5 on: 28 March 2024, 10:27:54 »
Good to know about Erling, in my case they failed as the mayonese in breather blocked the system in -20 degrees. Victor Reinz was recommended somewhere here in OOF.
Page created in 0.031 seconds with 20 queries.
