Pages: 1 2 3 4 [5]   Go Down
Author Topic: Arrival of new Vehicle.  (Read 19405 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Arrival of new Vehicle.
« Reply #60 on: 17 April 2024, 18:19:30 »
Changing the oil+filter is interesting,  if car isn't high enough you can't drop undertray flap down enough,  .....
you need a Pela oil-sucker-outerer  :y
 I'm of the old skool,, undo sump plug, and make a mess on the floor as the tray is positioned wrong,
Hoof'land storeman.
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite. Boxster. C1.
« Reply #61 on: 17 April 2024, 19:06:34 »
Me too.  :y :D
Women are like an AR35. lovely things, but nobody really understands how they work.
    • Astra 1.6 diesel
« Reply #62 on: 17 April 2024, 19:55:18 »
If you were really old school, you'd park it over a drain in the street and let it run down there  ;D
Diesel till I die
« Reply #63 on: 17 April 2024, 21:25:03 »
My oil-sucker-outerer can't be pushed down far enough to suck the oil from my classic and highly desirable Vauxhall. :-\
The tube is long enough but there is an obstruction of some kind.
Strange  ??? So how does the dip stick reach the oil if there's an obstruction ??  :-\
« Reply #64 on: 17 April 2024, 21:27:37 »
I've a Pela because one of my Smarts doesn't have a sump drain plug, but I do remember having a car where the under tray fouled the floor before it came off.
« Reply #65 on: 17 April 2024, 22:32:20 »
I'm considering it, given that the local tip let you dispose of about an egg cup full of oil each trip and I've got 2 20L containers of the stuff.
« Reply #66 on: 18 April 2024, 04:28:01 »
The Insignificant engine is a pita as the filter is at the back right-hand corner of the engine and officially requires a special funnel to get the oil to drain cleanly when the filter is removed... It's almost a subframe out job*. Sucking the oil out doesn't correct the stupid design.
It's not quite that bad, but the filter cap is buried in the depths of Narnia.
« Reply #67 on: 18 April 2024, 12:11:38 »
Exactly my thoughts.......The dipstick is extremely skinny for the last 5 or 6 inches and the tube simply can't be pushed in far enough. :-\
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #68 on: 18 April 2024, 17:06:01 »
Just give a good hard shove, the desirable Signum will think it's having a colonoscopy.  :D
« Reply #69 on: 18 April 2024, 21:18:58 »
Oooooer!  ;D ;D
biggriffin
« Reply #70 on: 19 April 2024, 15:03:39 »
 Remove front wheel, get a 1L oil bottle cut the front out, wedge under filter housing, undo filter, all drops into said bottle, then wiggle it out, without spilling any ;D ;D
Hoof'land storeman.
« Reply #71 on: 19 April 2024, 15:24:06 »
I have the same for the F-type, it actually has a metal tube inside the oil filler which passes down to the base of the sump by the drain hole to suck the oil through:
It is by far the easiest car I have ever changed oil and filter on  :o
« Last Edit: 19 April 2024, 15:26:54 by Marks DTM Calib »
« Reply #72 on: 23 April 2024, 08:55:57 »
I have a cheap £6 12v oil pump for my car, as its far easier than a Pela ;D.  But it doesn't work on her car with a proper dipstick, so I do use a Pela for that.
Both are easy to change oil on :)
countrywoman
  • worcestershire
    • skoda yeti
« Reply #73 on: 23 April 2024, 09:26:04 »
The Omega engine in the Austin hot rod is doing its own oil change, must remember to get a new sump plug washer------
« Reply #74 on: 23 April 2024, 15:02:17 »
Ah, but its stops the rust ;D
Pages: 1 2 3 4 [5]   Go Up
Page created in 0.059 seconds with 20 queries.
