Pages: 1 [2] 3  All   Go Down
Author Topic: Windscreen trim  (Read 38908 times)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Windscreen trim
« Reply #15 on: 21 September 2023, 22:40:55 »
so, back to the drawing board
I won't fill the gap with expanding foam  :P
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Windscreen trim
« Reply #16 on: 21 September 2023, 22:43:17 »
Must be the month for it....
Ouch
I can empathise
    • 530D M Sport, 330i Coupe
Re: Windscreen trim
« Reply #17 on: 21 September 2023, 22:51:38 »
Will have a look at my two tomorrow if it's not raining and post up pictures if it helps?
One thing I know is the silver car had the last (or last but one) genuine GM screen from Germany and it was a perfect fit, seem to recall that they sent two fitters out and they were old boys who'd done plenty of Omega's back in the day. Black car still has it's original screen so should be a good comparison. All the other Omega's i've owned had none genuine replacements (I think Pilkington make them as a special order when Autoglass etc require) over the years but they seemed to struggle fitting them and there were defects in the glass that meant distortions on the edges.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Re: Windscreen trim
« Reply #18 on: 21 September 2023, 22:53:45 »
My replacement wasnt fitted quite right and the outer trim has never fitted properly since.  >:( :'(
I took it off as it kept coming loose and it lies behind the shed.  ::)
I assume its just a cosmetic item and doesnt serve an important purpose ?
Re: Windscreen trim
« Reply #19 on: 21 September 2023, 22:54:06 »
Ouch
I can empathise
I was amazed that meteorites also used the A14, shame they didn't fly on the correct side of the carriageway.  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Windscreen trim
« Reply #20 on: 21 September 2023, 22:59:48 »
why amazed  :-\
loads of idiot people with UK driving licences can't sick to their side of the carriageway   :(
well, round by my neck of the woods anyway  ::)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Windscreen trim
« Reply #21 on: 21 September 2023, 23:09:13 »
I took it off as it kept coming loose and it lies behind the shed::)
£100 for a non genuine one on ebay
the seller ended one listing (lower trim inner )and  re-listed it ,after he increased the price when i enquired with part numbers  ::)
so I guess they are rare now
Re: Windscreen trim
« Reply #22 on: 21 September 2023, 23:28:56 »
Ok, there should be a vertical cap between the sides of the goalpost moulding and the glass... this is built into the frame to allow rainwater to flow up and off the screen at speed as the wipers clear it.
But yes, the frames and mouldings are all attached to the new screen prior to fitting. This allows the moulding to set the location and depth of the screen.
Dave, you screen looks to be set wrong in both position and depth... almost looks like they went to fit the trims afterwards and pulled the screen out of the aperture trying to get the trims to fit, obviously failing miserably.
If you can get the new frames and mouldings from VX then I would suggest that, otherwise get Autonoglass etc to supply it, watch them like a hawk and refuse to accept it if it doesn't look right, don't fit everything in the correct order or only send one person.
The Omega requires two people to fit the screen correctly (from Autonoglass following their second call back).
Think we covered the whys and wherefores both at that meet and in recent posts  ;)
Re: Windscreen trim
« Reply #23 on: 21 September 2023, 23:43:02 »
Apart from locating the screen during fitting, not much :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Windscreen trim
« Reply #24 on: 21 September 2023, 23:50:44 »
Thanks for the info DG  :)
that's what I thought  :y
I'm going to carefully remove the outer trim , see what delights are underneath , then decide
thanks to everyone for the help  :)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Windscreen trim
« Reply #25 on: 21 September 2023, 23:57:17 »
Oh , while I remember ,,,
Does anyone know a part number or source for the twist pins that secure the scuttle   :-\
or do I just google "hen's teeth from the saddle bag of a unicorn "
I guess they are rare too  ;D
I only have 2 black ones (which i assume are original) and 2 grey (which don't look original)  :(
Re: Windscreen trim
« Reply #26 on: 22 September 2023, 00:32:34 »
https://oeparts24.com/opel
90458358 :y
Also gives all the part numbers for screens, frames and mouldings :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: Windscreen trim
« Reply #27 on: 22 September 2023, 11:12:11 »
90458358 :y
Thanks Al  ;)
seems ,as expected ,the retainers are out of stock everywhere
Fortunately ,as a builder , u can obtain UNIVERSAL WINDOW TRIM & TRIM RETAINERS  :P
Re: Windscreen trim
« Reply #28 on: 22 September 2023, 13:31:01 »
90458358 :y
Thanks Al  ;)
Aka wood screws :D
Migv6 le Frog Fan
Re: Windscreen trim
« Reply #29 on: 22 September 2023, 17:30:42 »
Therein lies the cause of the problem. They popped it in after the screen was fitted. Eejits.  >:(
Pages: 1 [2] 3  All   Go Up
