I'm sort of settling on £850 incluing the new wishbone set and spare rear electric blind. Also have some other spares to throw in, fan belts, plugs, filters, gaskets, bulbs, crank sensor, cam sensor etc..
It has the elite HID dipped bulbs and some high watt day white headlight bulbs to match. The headlights have the aluminium adjusters fitted and the lenses are sparklingly clear, like new. Led front side lights and wing indicator lights.
I appreciate people may be buying from afar so do let me know any particular photos you want taken. Also I've made a list of issues:
Rear electric blind needs a tug to start. But there is an unfitted spare.
minor rust on rear n/s arch
various scrapes including o/s arch, I think they are all visible in the pics
winscreen bottom n/s - a white patch, also visible in pics. I had forgotten this as it was like it when I bought the car and hasn't changed in 10+ years. I did take a picture of it in 2011 to check if it grew, I'll see if I can find it. It must be damp in the laminate.
glove box latch works (amazingly) but needs handling with care.
wheel edges a littled scraped as in the pics but fully functional, I should have wire brushed them and touched them up but will leave to new buyer.
Current miles 129,779
oil and filter change at 129,409, 124,767, 120,860 etc...
air filter and charcoal pollen filter 123,988
2 new coil packs and Bosch plugs at 120,782
4 new tyres at 119,758
3 spare keys (1 securely hidden on the car just in case)
new ETA exhaust, cat back, at 107,292
boot and bonnet struts replaced at 101,656 and 118,357 respectively
replaced coolant header tank (and fixed level sensor!) at 125,699. You can't get these tanks anymore.
Here's the mileage chart from new. White dot is when I bought it, maroon dots are events - mot, service, fixed something etc..
