Author Topic: Removing an auto gear knob  (Read 1295 times)
ChrisPee
  • Kent
    • Omega Select estate
« on: 03 July 2020, 00:14:41 »
Hi chaps, as the title says - I'm ordering new leather waiters and wondered how easy it is to remove an auto knob? I fitted them easily on my manual, but that has a smaller knob (ooh er missus).
Re: Removing an auto gear knob
« Reply #1 on: 03 July 2020, 06:53:44 »
Either cut it off or dismantle half the car to remove the lever :y
Plenty of recent discussions for fitting the new one...
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #2 on: 03 July 2020, 07:29:11 »
Do tell ::)
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #3 on: 03 July 2020, 09:39:10 »
Leave it in place.
Remove the old gaiter by cutting the first 10mm (approx) of vertical stitching.
Your new gaiter will almost certainly have a much bigger neck, that will fit over the knob and need gathering to hold it in place. Mine came with a cable tie, which worked but was ugly. I slipped some lockwire into the sleeve instead, twisted the ends together, and tucked them in so nothing was visible which looked a lot better.
The handbrake gaiter was the same, but I kept the cable tie as it wasn't visible.
You'll probably need to do a bit of adjusting to get them to fit to the plastic mounts; a sharp blade, contact adhesive and some stretching - standard trimming techniques - takes care of that.
ChrisPee
  • Kent
« Reply #4 on: 03 July 2020, 10:09:30 »
Thanks guys. Waiters indeed  ;D :-[ :y
Page created in 0.031 seconds with 20 queries.
