Author Topic: 0.24 amps current  (Read 2777 times)
0 Members and 3 Guests are viewing this topic.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
0.24 amps current
« on: 12 October 2014, 15:24:04 »
Hello
Just changed battery as it died after six years (Bosch). All OK, charging more than 14V. During this repair I wanted to check how much current is consumed while car is parked. I closed the doors but did not lock them, put amp. meter between battery minus and minus cable and found that there is after 15 seconds about 0.24A current. It did not change within a couple of minutes. The value seems quite high for me. Is this normal? Just think that about in 4 hours 1Ah is used, 6Ah in a day and night. After ten days 60Ah.
Any experience about this, strange!
4x4
Re: 0.24 amps current
« Reply #1 on: 12 October 2014, 15:44:48 »
Dont forget some items are still active for about 15 mins after last door is closed
« Reply #2 on: 12 October 2014, 15:45:45 »
Yes, that is a bit high. Around 80mA would be more typical, but it varies with spec.
« Reply #3 on: 12 October 2014, 15:47:14 »
Yes, the accessory delay relay takes 10-15 minutes. Plug something into the rear lighter socket or leave the interior light on and wait until it's turned off. :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #4 on: 12 October 2014, 15:48:05 »
You can pull fuses 'til the amps drop and you've found the affected circuit :)
RIP Paul Lovejoy
polilara
  • Finland
« Reply #5 on: 12 October 2014, 16:47:37 »
Hello all
Thanks for all comments, I do the 15 minutes test first and then start to pull off fuses if I am remarkably over 80 mA. Keep you informed.
polilara
  • Finland
« Reply #6 on: 14 October 2014, 19:10:03 »
OK, now some official results:
I put charger without telephone to rear lighter socket to see red led when there is current, then amp. meter between battery minus and minus cable, double locked doors with remote so all alarms went on. After 10 seconds current stabilized to something 0.25A. After about six minutes I heard the "click", charger led did not lid anymore, current dropped to about 0.014A, yes 14mA, Good. My meter is yellow and nice but not FLUKE, perhaps worth 10 Euro. However, I believe that there is a remarkable drop of current after this six minutes period and thus all should be okay.
Webby the Bear
  • Northampton
« Reply #7 on: 14 October 2014, 19:29:25 »
Good result.
My meter cost £1.89  ;D
RIP Paul Lovejoy
elvin315
  • Catskill, New York, USA
  • Catera...Cadillac's unloved stepchild.
« Reply #8 on: 14 October 2014, 23:16:27 »
I usually grab a ground and lick the "+". Not very accurate but better than :D
Is that all there is, is that all there is
If that's all there is my friends, then let's keep dancing
Let's break out the booze and have a ball, If that's all there is
Page created in 0.052 seconds with 20 queries.
