Pages: 1 ... 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42   Go Down
Author Topic: Mechanic School Blog  (Read 106513 times)
0 Members and 3 Guests are viewing this topic.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Mechanic School Blog
« Reply #495 on: 11 April 2013, 19:32:24 »
New multimeter  8) 8) 8) 8) 8) 8) 8) £1.39!!!!
and its pocket sized  8) 8) 8)
RIP Paul Lovejoy
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
« Reply #496 on: 11 April 2013, 20:08:08 »
get back to school you mitcher ;D :D :D :D :D
long live the magic tree
its good to be back
Webby the Bear
  • Northampton
« Reply #497 on: 11 April 2013, 20:21:12 »
lol wish I was mate  ::) ;D ;D
RIP Paul Lovejoy
ozzycat
    • hyundia i30
« Reply #498 on: 11 April 2013, 20:44:25 »
how long you off for
its good to be back
Webby the Bear
  • Northampton
« Reply #499 on: 11 April 2013, 20:49:56 »
back on Monday thank god... get away from the wife, the step kids and the house  ::) ;D
RIP Paul Lovejoy
ozzycat
    • hyundia i30
« Reply #500 on: 11 April 2013, 21:00:24 »
not too bad ...you could go and cheer emd up hes  abit down in the dumps at the mo
its good to be back
Webby the Bear
  • Northampton
« Reply #501 on: 11 April 2013, 21:14:45 »
why whats up with him  ???
RIP Paul Lovejoy
ozzycat
    • hyundia i30
« Reply #502 on: 11 April 2013, 22:26:56 »
its good to be back
Webby the Bear
  • Northampton
« Reply #503 on: 15 April 2013, 18:13:12 »
Finally back to school  8) 8) 8) so let's get down to it...
brake drums today...
these as you probably already know are usually found in the rear. you release the handbrake and slacking off the handbrake cable. you take the wheel off and in the case of the car I worked on ('97 Renault megan) you break loose and remove the axel nut as this is securing the brake drum to the hub assembly.
Take off the drum.
you will be faced with what I felt was the most complicated looking thing in the world  :D :D :D :D
in short though the two brake shoes are on either side. I undid the two securing pins in the middle, prised the spring off that held the handbrake leaver to the right hand shoe and with the tension off the whole assembly everything came out quite easily.
you must however take a photo of everything unless you are Rain Man and can remember how it all went back together.
this is a pic of the shoes out. one is still attached to the handbrake cable and I just popped this loose....
Also in this pic you can see 6 little oval areas where the brake shoes sit. I cleaned these up with a small file and emery cloth and before replacement applied copper anti-seize paste.
this is of it all back together  :y
When I put it back together I found the easiest way was to attach the bottom shoes together with the small spring and use the shoes for leverage to slot them in to position. the big top spring was a bit of a pain but I overcame this with a pair of pliers.
At this point you should also use the handbrake adjuster to back off the cable so you can fit the drum back on. keep doing it up until you have a bit of resistance when spinning the drum. tighten your handbrake cable. job jobbed  :y :y :y
there is a ''leading'' and a ''trailing'' shoe. the leading shoe is towards the front of the car and is the one that takes the most wear.
when working out whether you need new ones..... measure the friction material and compare to spec. measure the diameter of the brake drum and compare to spec.
I found it was challenging at times especially for my first go. but alls well that ends well  :y
RIP Paul Lovejoy
STMO123
« Reply #504 on: 15 April 2013, 18:20:43 »
Oh yes. I've seen a few of those springs disappear under 'things'. ;D
Webby the Bear
  • Northampton
« Reply #505 on: 15 April 2013, 18:22:18 »
That reminds me... I wore my new safety glasses all day. they've already saved my eyes!!!  :o I had a spring fire off in to my face and ricochet off my glasses  :o :o :o :o :o
RIP Paul Lovejoy
« Reply #506 on: 15 April 2013, 18:23:39 »
Oh boy, Webby, are you going to enjoy doing your Omega handbrake. NOT!!!!!
Frakking 'orrible things
« Reply #507 on: 15 April 2013, 18:24:03 »
Also available .......  twin leading shoes  ;)  ;)  ;)
http://www.retroanaconda.com/landrover/wp-content/uploads/2010/04/DSC01173.jpg  :y
Webby the Bear
  • Northampton
« Reply #508 on: 15 April 2013, 18:25:45 »
oh yeah forgot that.... two cylinders top and bottom. its also worth noting that those cylinders I believe have mini pistons inside which is what pushes the shoe against the drum when braking  :y
RIP Paul Lovejoy
« Reply #509 on: 15 April 2013, 18:27:10 »
They do indeed & make a mess inside your drums when they leak.  ???  ;)
Pages: 1 ... 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42   Go Up
Page created in 0.029 seconds with 20 queries.
