Author Topic: V6 Plenum removal - addendum for 2.6 & 3.2  (Read 16611 times)
Markjay
  • London
« on: 10 April 2007, 15:02:56 »
Plenum removal may be required for several reasons, such as camcover gaskets replacing, cambelt replacement or cam timing.
The guide describing the plenum removal can be found here:
Removing V6 plenum
http://www.omegaowners.com/forum/index.php?topic=90657.0
Essentially the plenum removal instructions for the 2.5 & 3.0 engines are still valid, but the newer 2.6 & 3.2 engines are slightly easier to work on due to the fact that there are fewer components to remove, e.g. no ICV, EGR, or HT leads.
If you have one of the newer engines, you might find it easier to follow the instructions below for plenum removal and then proceed with the 2.5 & 3.0 guides for the operation you intend to carry out:
Changing the V6 Cam Cover Gaskets
http://www.omegaowners.com/forum/index.php?topic=90542.0
V6 Cambelt change
http://www.omegaowners.com/forum/index.php?topic=90518.0
« Last Edit: 27 September 2011, 08:28:27 by Jimbob »
Alas, no more Omegas....
Markjay
  • London
Re: V6 Plenum removal - addendum for 2.6/3.2 engin
« Reply #1 on: 10 April 2007, 15:04:01 »
This is an overview of the items that need to be disconnected:
« Last Edit: 24 July 2007, 16:38:20 by TheBoy »
Markjay
  • London
« Reply #2 on: 10 April 2007, 15:04:58 »
Below is a detailed description:
Markjay
  • London
« Reply #3 on: 10 April 2007, 15:06:46 »
« Last Edit: 24 July 2007, 16:39:11 by TheBoy »
Markjay
  • London
Re: V6 Plenum removal - addendum for 2.6 & 3.2
« Reply #4 on: 10 April 2007, 15:07:56 »
« Last Edit: 24 July 2007, 16:39:44 by TheBoy »
Markjay
  • London
« Reply #5 on: 10 April 2007, 15:08:36 »
« Last Edit: 24 July 2007, 16:40:38 by TheBoy »
Markjay
  • London
« Reply #6 on: 10 April 2007, 15:09:21 »
On reassembly, observe the relevant torque settings as detailed in Marks DTM guide:
http://www.omegaowners.com/forum/index.php?topic=90519.0
« Last Edit: 27 September 2011, 08:29:20 by Jimbob »
Page created in 0.039 seconds with 21 queries.
